Get the Widest Variety of Axial Torsion Test Machines
Choose from 15 different models with 100's of configurations
Choose from 15 different models with 100’s of configurations which allows you to optimize your testing capabilities and pick exactly what you need. While other companies only have 4 or 5 frames to choose from, our extensive product line of axial torsion test machines gives you the options you have been craving for. Why do we give you so many options? More choices mean fewer compromises!
Each solution can be custom designed to meet your exact application, both now and in the future. Today you might be testing luers and next you might be testing syringes. We've got you covered. Our axial torsion testers give you the freedom you need to keep testing for years to come.
Family | Axial Load Capacity | Torsion Capacity | Applications |
Low Force | |||
131AT | 1 or 2.2 kN (225 or 500 lbf) |
1 to 20 Nm (9 to 177 in-lb) |
Customizable for a wide range of applications - Static or Dynamic |
530E2 | 0.8 to 2.5 kN (180 to 560 lbf) |
1 to 10 Nm (8 to 89 in-lb) |
Fatigue - Dynamic |
240AT | 1 or 4.4 kN (225 or 1000 lbf) | 20 Nm (177 in-lb) | UTM with torsion - Static |
830E3 | 1.6 to 5 kN (360 to 1125 lbf) | 10 to 100 Nm (89 to 885 in-lb) | Fatigue - Dynamic |
310AT | 5 kN (1125 lbf) | 20 to 300 Nm (177 to 2655 in-lb) | UTM with torsion - Static |
130AT | 2.2 to 10 kN (500 to 2250 lbf) | 1 to 100 Nm (9 to 885 in-lb) | Ideal for chambers & large samples that require extra space - Static |
Medium Force | |||
311AT | 10 kN (2250 lbf) | 20 to 300 Nm (177 to 2655 in-lb) | UTM with torsion - Static |
312AT | 25 kN (5625 lbf) | 20 to 300 Nm (177 to 2655 in-lb) | UTM with torsion - Static |
830E4 | 15 kN (3375 lbf) | 10 to 200 Nm (89 to 1770 in-lb) | Fatigue - Dynamic |
830E5 | 30 kN (6750 lbf) | 10 to 200 Nm (89 to 1770 in-lb) | Fatigue - Dynamic |
High Force | |||
313AT | 50 kN (11250 lbf) | 20 to 300 Nm (177 to 2655 in-lb) | UTM with torsion - Static |
830E6 | 50 kN (11250 lbf) | 10 to 200 Nm (89 to 1770 in-lb) | Fatigue - Dynamic |
314AT | 100 kN (22500 lbf) | 20 to 300 Nm (177 to 2655 in-lb) | UTM with torsion - Static |
315AT | 150 kN (33750 lbf) | 20 to 300 Nm (177 to 2655 in-lb) | UTM with torsion - Static |
316AT | 300 kN (67000 lbf) | 20 to 300 Nm (177 to 2655 in-lb) | UTM with torsion - Static |
Ready to configure your axial torsion test machine? Contact us by completing the form to help you select the right machine. |
Contact us to help you select the right machine.
Contact Us Now!
Common Axial Torsion Applications
- Biomedical
- Luer fittings - leakage and separation forces (ISO 80369, ISO 594)
- Metallic Medical Bone Screws (ASTM F543)
- Syringes (ISO 7886-1, ISO 8537-C, ISO 11040-4, ISO 11608-5)
- Child-Proof Pharmaceutical Bottles (ASTM D7860)
- Adhesive properties of biomaterials
- Orthopedic research of bones, tissues, joints including spine, hip, knee,
shoulder, wrist, finger, ankle, foot & osteosynthesis. - Medical device and implant certification for static and fatigue life
endurance including ISO 7206, ASTM F2068, F1717, F2077, F2267, F1798, and
ISO 12189.
- Engineering Teaching
- Constitutive modeling
- Thin walled tubing
- Engineering Mechanics
- Biomedical
- Characterization of materials including polymers, metals, ceramics, cement
and adhesives, shape memory alloys, coatings, ceramics and composites.Wire - Tools
- Fasteners
- Shafts
- Consumer Products
- Electronics
- Research institutions
- Simulating real life stresses (multiaxial)
- Product durability under biaxial loading
- Combining different test modes to speed development
- And so many more! We have a solution for every application.
Take advantage of our free application support. Our application experts will help you tweak an existing design, weigh the trade-offs between multiple solutions, or scope a custom system. 75% of the time we can improve your selection with just a few questions. Contact us for help selecting the right system for your application
You Can Pick the Right Axial Torsion Test Machine in 4 Easy Steps
First, select your frame and actuator (Step 1) by axial load capacity and torque capacity, then complete your system by selecting your controller software(Step 2) and accessories(Step 3). Choose from a wide range of controller software packages, grips, fixtures, chambers, video extensometers and more, are all designed to perform thousands of ASTM, ISO, EN, DIN and JEDEC industry standard test methods.
When you're ready to complete your system, contact us(Step 4), and an application expert will help you optimize your system to your test requirements and budget.
Step 1: Select Your Frame
131AT Axial Torsion Test Machine
Type: Electromechanical or Electrodynamic
Axial Load Capacity: 1 or 2.2 kN (225 or 500 lbf)
Torque Capacity: 1 to 20 Nm (9 to 177 in-lb)
Ideal solution for applications where tension, compression and torsion tests are required. The 131AT frame can be placed vertically or horizontally on a table. Most affordable solution. The modular design allows for cost-effective customizability for a wide range of applications. The 131 is ideal in cramped lab spaces where space is a premium.
Request a 131AT spec sheet
530E2 Axial Torsion Test Machine
Type: All-Electric Dynamic
Axial Load Capacity: 0.8 to 2.5 kN (180 to 560 lbf)
Torque Capacity: 1 to 10 Nm (8 to 89 in-lb)
The 530E2 Axial Torsion Test Machine serves static, dynamic and fatigue testing applications where a material, product or device experiences combined axial and torsional loading conditions. Ideal for applications that require a dynamic speed range and situations where table space is limited. The 530E2 frame can be placed vertically or horizontally on a table. Commonly used for low force biological tissue applications.
Request a 530E2 spec sheet
240AT Axial Torsion Test Machine
Axial Load Capacity: 1 or 4.4 kN (225 or 1000 lbf)
Torque Capacity: 20 Nm (177 in-lb)
The design features a mechanically stiff universal test machine with torsion motor either mounted on the moving crosshead or baseplate mounted. Ideal for high elongation materials such as rubber, elastomer, plastic, etc. as well as tensile, compression, torsion and combined biaxial tests. The 240AT load frame is compact and lightweight and applies to situations where lab table space is limited. The 240 family has multiple frames featuring high travels, high speeds, and is a premium UTM package. Best value.
Request a 240AT spec sheet
830E3 Axial Torsion Test Machine
Axial Load Capacity: 1.6 to 5 kN (360 to 1125 lbf)
Torque Capacity: 10 to 100 Nm (89 to 885 in-lb)
The 830E3 systems cover a wide range of biaxial load capacities and applications. Ideal for low force load controlled fatigue testing applications. The larger frame is ideal for chambers and larger samples. 830 systems are modular, so they can be configured in a variety of ways.
Request a 830E3 spec sheet
310AT Universal Test Machine with Torsion Add-on
Axial Load Capacity: 5 kN (1125 lbf)
Torque Capacity: 20 to 300 Nm (177 to 2655 in-lb)
The Torsion Channel Add-on package expands a universal test machine into a system that performs both torsion and combined axial-torsion (biaxial) tests. 310AT add-ons deliver great versatility at an affordable price for anyone that seeks the benefits of a universal test machine combined with torsion and biaxial test applications. In addition to torsion and combined axial torsion applications, these universal test machines perform the full gamut of mechanical tests including tensile, compressive, bend, bond, flexural, fracture, peel, shear, tear, stress relaxation, and short term creep tests. Best value in its force class.
Request a 310AT spec sheet
130AT Axial Torsion Test Machine
Axial Load Capacity: 2.2 to 10 kN (500 to 2250 lbf)
Torque Capacity: 1 to 100 Nm (9 to 885 in-lb)
The 130AT column spacing enables use of environmental chambers and large test sample test requirements. Maximum force capacity is 10 kN (2250 lbf). The 130AT is the ideal solution for test labs where both tension, compression and torsion tests are required.
Request a 130AT spec sheet
311AT Universal Test Machine with Torsion Add-on
Axial Load Capacity: 10 kN (2250 lbf)
The Torsion Channel Add-on package expands a universal test machine into a system that performs both torsion and combined axial-torsion (biaxial) tests. 311AT add-ons deliver great versatility at an affordable price for anyone that seeks the benefits of a universal test machine combined with torsion and biaxial test applications. In addition to torsion and combined axial torsion applications, these universal test machines perform the full gamut of mechanical tests including tensile, compressive, bend, bond, flexural, fracture, peel, shear, tear, stress relaxation, and short term creep tests. Best value in its force class.
Request a 311AT spec sheet
312AT Universal Test Machine with Torsion Add-on
Axial Load Capacity: 25 kN (5625 lbf)
The Torsion Channel Add-on package expands a universal test machine into a system that performs both torsion and combined axial-torsion (biaxial) tests. 312AT add-ons deliver great versatility at an affordable price for anyone that seeks the benefits of a universal test machine combined with torsion and biaxial test applications. In addition to torsion and combined axial torsion applications, these universal test machines perform the full gamut of mechanical tests including tensile, compressive, bend, bond, flexural, fracture, peel, shear, tear, stress relaxation, and short term creep tests. Best value in its force class.
Request a 312AT spec sheet
830E4 Axial Torsion Test Machine
Axial Load Capacity: 15 kN (3375 lbf)
Torque Capacity: 10 to 200 Nm (89 to 1770 in-lb)
The 830E4 systems cover a wide range of biaxial load capacities and applications. Ideal for low force load controlled fatigue testing applications. 830 systems are modular, so they can be configured in a variety of ways.
Request a 830E4 spec sheet
830E5 Axial Torsion Test Machine
Axial Load Capacity: 30 kN (3375 lbf)
The 830E5 systems cover a wide range of biaxial load capacities and applications. Ideal for low force load controlled fatigue testing applications. 830 systems are modular, so they can be configured in a variety of ways. Compared to servohydraulic axial torsion tet machines, the 830E5 offers many advantages.
Request a 830E5 spec sheet
313AT Universal Test Machine with Torsion Add-on
Axial Load Capacity: 50 kN (11250 lbf)
The Torsion Channel Add-on package expands a universal test machine into a system that performs both torsion and combined axial-torsion (biaxial) tests. 313AT add-ons deliver great versatility at an affordable price for anyone that seeks the benefits of a universal test machine combined with torsion and biaxial test applications. In addition to torsion and combined axial torsion applications, these universal test machines perform the full gamut of mechanical tests including tensile, compressive, bend, bond, flexural, fracture, peel, shear, tear, stress relaxation, and short term creep tests.
Request a 313AT spec sheet
830E6 Axial Torsion Test Machines
The 830E6 systems cover a wide range of high force biaxial load capacities and applications. Ideal for low force load controlled fatigue testing applications. 830 systems are modular, so they can be configured in a variety of ways. Compared to servohydraulic axial torsion tet machines, the 830E6 offers many advantages.
Request a 830E6 spec sheet
314AT Universal Test Machine with Torsion Add-on
Axial Load Capacity: 100 kN (22500 lbf)
The Torsion Channel Add-on package expands a universal test machine into a system that performs both torsion and combined axial-torsion (biaxial) tests. 314AT add-ons deliver great versatility at an affordable price for anyone that seeks the benefits of a universal test machine combined with torsion and biaxial test applications. In addition to torsion and combined axial torsion applications, these universal test machines perform the full gamut of mechanical tests including tensile, compressive, bend, bond, flexural, fracture, peel, shear, tear, stress relaxation, and short term creep tests. Best value in its force class.
Request a 314AT spec sheet
315AT Universal Test Machine with Torsion Add-on
Axial Load Capacity: 150 kN (33750 lbf)
The Torsion Channel Add-on package expands a universal test machine into a system that performs both torsion and combined axial-torsion (biaxial) tests. 315AT add-ons deliver great versatility at an affordable price for anyone that seeks the benefits of a universal test machine combined with torsion and biaxial test applications. In addition to torsion and combined axial torsion applications, these universal test machines perform the full gamut of mechanical tests including tensile, compressive, bend, bond, flexural, fracture, peel, shear, tear, stress relaxation, and short term creep tests. Best value in its force class.
Request a 315AT spec sheet
316AT Universal Test Machine with Torsion Add-on
Axial Load Capacity: 300 kN (67000)
The Torsion Channel Add-on package expands a universal test machine into a system that performs both torsion and combined axial-torsion (biaxial) tests. 316AT add-ons deliver great versatility at an affordable price for anyone that seeks the benefits of a universal test machine combined with torsion and biaxial test applications. In addition to torsion and combined axial torsion applications, these universal test machines perform the full gamut of mechanical tests including tensile, compressive, bend, bond, flexural, fracture, peel, shear, tear, stress relaxation, and short term creep tests. Best value in its force class.
Request a 316AT spec sheet
Custom Axial Torsion Solutions
Don't see exactly what you need? We will take that challenge! Our application expert will help you find exactly what you need for your application. Fortunately, with our large number of standard products and a massive number of modular sub-assemblies, we can tweak an existing design quickly and economically.
Contact us to get started
Step 2: Select Your Controller Software
Choose From 190+ Pre-configured Software Solutions
Pre-configured solutions meet customer specifications and budget for a wide range of test applications. Industry standard-specific software modules, enhanced features and custom calculations are just a few of the options to choose from with Newton.
Shop Controller Software
Step 3: Select Your Accessories
Choose From 1,000's of Accessories
Choose from a wide variety of test accessories for a wide variety of purposes. These accessories include grips, environmental chambers, transducers, and sample preparation items. With these accessories, you can have confidence that your specimens will be tested consistently, correctly, and will yield ideal results.
Shop Accessories
Step 4: Contact Us
Ready to configure your test machine?
Contact us to confirm your configuration, request prices, and place your order.
