Single Purpose Test Machines
TestResources special purpose test machines are single purpose mechanical test machines. They include manual and digital impact test machines, guided bend test machines and Elmendorf tear testers.
326 Electromechanical Compression Test Machine
Model: 326
Load Capacity: 300 kN (67500 lbf)
Maximum Speed: 40 mm/min (1.6 ipm)
The Electromechanical Compression Test Machine is an ideal solution to high capacity compression, flexural bend and shear testing applications.
402 Family Izod and Charpy Impact Strength Test Machine
Model: 402D-Z1
Force: Pendulum Potential Energy 1 to 50 J (Izod) and 0.5 to 150 J (Charpy)
Force: 3.5 m/s at Impact
The machine features a digital controller that calculates impact energy and impact angle. The machine features a digital controller that calculates impact energy and impact angle.
404-ANSI Z87.1 Drop Weight Impact Test Machine
Type: 404-ANSI-Z87.1
404-ANSI-Z87.1 drop weight impact test machine is designed to test glass and plastic products to determine impact shatter resistance per ANSI Z87.1 specifications for the safety of the end user.
404D Family Drop Dart Impact Tester
Model: 404D
The 404D Family is designed according to ASTM D1709 & ISO 7765-1 standard tests for impact resistance of plastic film by a free falling dart.
405 Family Elmendorf Impact Resistance Test Machine
Model: 405
405 Family test machines is used to determine the tear force of paper, fabrics, and plastics. Notched specimens are struck by a falling pendulum and the energy required to tear the test specimen is determined.
420 Family Guided Bend & Tensile Test Hydrualic Fixture
Model: 420M
Simple cost effective solution to test welds in bending and tensile modes.
4115-D2210 Burst Tester
Model: 4115-D2210
Speed: 170 ± 15 mL/min
The Mullen Test Burst Tester is made specifically to measure bursting strength using oil pressure. The machine is designed to measure the force required to crack the grain of leather by steady hydraulic pressure on a diaphragm of definite diameter applied to the flesh side of the specimen to form a sphere.
4625-D1238 Melt Flow Indexer
Model: 4625-D1238
Counter Weights: 1100g, 2060g, 3700g, 3700g, 4900g<
Melt Indexer is made according to ASTM D1238. MI value means to measure polymeric material at certain temperature and under fixed load, the flow extrusion weight within specific time. Therefore, melt Indexer can test melt polymeric material flow speed rate, the higher M1 value means fluidity is also higher.
ASTM C39 Concrete Compression System
Model: C39
Designed in accordance to ASTM C39. 22.2 kN to 2224 kN (5000 lbf to 500,000 lbf) testing range.
