Multi Axis Shake Table
B-MAX Multi-Axis Shake Table is designed to perform durability and performance evaluation of automotive components and sub-assemblies. The computerized control system delivers user friendly, repeatable and reproducible operation with powerful application software that covers a wide range of testing requirements. Vibration inputs can be generated with up to six degrees of freedom (6 DOF) individually or collectively. The fatigue rated servoactuators feature swivel mounting on both ends to isolate the actuator rods from side loads and lateral accelerations. All actuators react vertically into the reaction mass and are coupled with lever arms to transfer displacements to the table.The user friendly real-time software enforces any desired 6 DOF table motion history at speeds restricted only by hydraulic power capacity.
TEST APPLICATIONS
  • Durability
  • testing and performance evaluation of automotive components
  • Squeak and Rattle tests
  • Test instrument Panels and seats
  • Testing fuel tanks, radiators and power train mounting systems
  • Batteries, supporting structures and exhaust system of LCV
  • Engine cooling modules test
FEATURES & BENEFITS
  • Single axis to 6 axis vibration
  • Frequency 0.01 to 50 Hz
  • Displacement up to 250 mm (10 inches)
  • Table size 3m x 2m (10 x 6.7 foot)
  • Low friction low maintenance swivels
  • Powerful digital controller for synchronous multi-axis control and data acquisition
  • Highly efficient hydraulic powerpack with power saving 'Green' features.
  • 12 month warranty and customer support services.
  • Meets or exceeds national and international accuracy standards for materials testing systems.
