B-603 CV Joint Test System enables constant velocity testing per SAE J 2028. The test setup evaluates the quality of CV joints by simulating the actual movements as in automobiles with a 2360 controller. The two mounting blocks bolted on the frame support a hydraulic motor and a torque load cell coupled with transducers for precision measurement and customized fixtures to hold the test specimen. The mounting blocks have provision to rotate (+/-45 degrees) and also to move to and fro adjusting to the varying lengths of specimen.
TESTING APPLICATIONS
- Articulation torque test to measure the torque required to rotate the shaft, when articulated at any point between 0 to 50 degrees
- Measures backlash of the joint, maximum articulation angle, maximum articulation angle and force at any articulation angle from 50 degrees
- Optional testing under cold temperatures to -400 C and under hot temperatures to 2000 C
- Radial expansion measurement
FEATURES & BENEFITS
- Hydraulic torque actuator
- Torque cell
- Suitable for static and dynamic testing
- "Green" highly efficient hydraulic power pack
- 2360 controller for synchronous control and data acquisition
- Optional environmental chambers for varying specimen lengths
- 12 month warranty and customer support services
- Meets or exceeds national and international accuracy standards for materials testing systems
