Tire Test Machine
B-607 Tire Test Systems evaluate both static and dynamic properties of tires, including durability under constant as well as road simulation loading. The test system features two carriages with spindle assemblies and can test two tires simultaneously. The wheel load is adjustable with maximum load of 100 kN (22,500 lbf) applied through two servo hydraulic actuators. Tires sized 300 mm to 1,700 mm (12 in. to 67 in.) in diameter can be tested at speeds to 300 km/h (190 mph). The system measures all forces and moments acting between the tire and drum with tests in line with ECE, DOT and SAE standard practices. Mechanical stoppers, proximity sensors and software limits prevent the wheel rim from coming in contact with the high speed rotating drum if the tire bursts. Additional safety features include a meshed door around the testing area and an enclosure surrounding the belt running on the motor.
TESTING APPLICATIONS
  • Durability test
  • Performance evaluation test
  • Measurement of dynamic growth of rotating tire as per ECE R75
  • Radial load test
FEATURES & BENEFITS
  • Load range to 100 kN (22,500 lbf)
  • Carriages on linear motion guides
  • Dual carriage capability
  • 2360 computerized digital controller with synchronous multi axis control and data acquisition
  • "Green" highly efficient hydraulic power pack
  • Optional laser based optical system for measuring dynamic growth of the tire
  • 12 month warranty and customer support services.
  • Meets or exceeds national and international accuracy standards for materials testing systems.
