Used Test Machine
Used Test Machine
Pre-owned electromechanical test machine.
Specifications:
  • Single Column load frame
  • Rated: 5 kN (1125 lbf)
  • Travel: 525 mm (21 in)
  • Position control resolution: 0.1 micron
  • Speed: user settable 1 to 500 mm/min (0.04 to 20 ipm)
  • Tension and compression
  • Space to column: 65 mm (2.65 in)
  • Dust protection bellows
  • Adjustable limit switches
  • Footprint 12 in wide x 16 in deep
  • Weight 90 lb
  • Tabletop system
  • Software: Upgraded with Newton controller. Learn more about Newton
Availability is constantly changing, contact us to get current information on available test machines.
Contact us to ask about our current availability
While we make every effort to provide accurate specifications, these descriptions are provided as a guide only. TestResources does not guarantee any specifications on the test systems. Contact us to confirm specifications and availability.
