Pre-owned single column tabletop tester.
Specifications:
- Model: Instron 3345
- Capacity: 5 kN (1125 lbf)
- Minimum speed: 0.05 mm/min (0.002 in/min)
- Maximum speed: 1000 mm/min (40 in/min)
- Vertical test space: 1123 mm (44.2 in)
- Horizontal test space: 100 mm (3.9 in)
- Height: 136 cm (54 in)
- Width: 38 cm (15 in)
- Single column load frame
- Tabletop system
- Software: Upgraded with Newton controller. Learn more about Newton
Contact us to ask about our current availability
While we make every effort to provide accurate specifications, these descriptions are provided as a guide only. TestResources does not guarantee any specifications on the test systems. Contact us to confirm specifications and availability.
TestResources, Inc. products and services are not endorsed by, affiliated with or sponsored by Instron Corporation. Instron® is a registered trademark owned by Illinois Tool Works, Inc.
