Used Instron 3366
Used Instron 3366
Used Instron 3366
Pre-owned dual column tabletop tester.
Specifications:
    • Model: Instron 3366
    • Capacity: 10 kN (2250 lbf)
    • Minimum speed: 0.005 mm/min (0.0002 in/min)
    • Maximum speed: 500 mm/min (20 in/min)
    • Crosshead travel:1122 mm (44.2 in)
    • Vertical test space: 1193 mm (47 in)
    • Column space: 420 mm (16.5 in)
    • Footprint dimensions: 158 x 76 x 71 cm (62 x 30 x 28 in)
    • Dual column load frame
    • Tabletop system
    • Software: Upgraded with Newton controller. Learn more about Newton
Availability is constantly changing, contact us to get current information on available test machines.
Contact us to ask about our current availability
While we make every effort to provide accurate specifications, these descriptions are provided as a guide only. TestResources does not guarantee any specifications on the test systems. Contact us to confirm specifications and availability.
TestResources, Inc. products and services are not endorsed by, affiliated with or sponsored by Instron Corporation. Instron® is a registered trademark owned by Illinois Tool Works, Inc.
