Pre-owned electromechanical single column test machine.
Specifications:
- Manually adjustable vertical test space: 787 mm (31 in)
- Actuator test stroke: 96.5 mm (3.8 in)
- Modes: Tension & Compression
- Controlled speed adjustable: 0.02 to 25 ipm
- Electromechanical
- Single column load frame
- Tabletop system
- Software: Upgraded with Newton controller. Learn more about Newton
Contact us to ask about our current availability
While we make every effort to provide accurate specifications, these descriptions are provided as a guide only. TestResources does not guarantee any specifications on the test systems. Contact us to confirm specifications and availability.
